Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - toyota heads replacement
View Single Post
Old 08-04-2006, 04:43 AM   #3 (permalink)
TONY
Guest
Posts: n/a
View TONY's Photo Gallery
Re: toyota heads replacement
yeah its coming from the head i took it apart and i saw some metal
chips on the valves
[email]SBKyler2@gmail.com[/email] wrote:[color=blue]
> Tony,
> Are you sure its coming from the heads?
> I have an 86 4Runner with a 22RE engine (injected). I have come to
> learn that a very common problem with Toyota's is the timing chain.
> (Yes, its a chain and not a belt, but possibly not the case for ALL
> toyota engines). Anyway, what happens is after a few miles (100k or so)
> the timing chain gets so loose by the tensioner either falling off and
> dropping into the oil pan or the chain stretching that the chain begins
> to tap on and wear a groove through the chain cover. Then, once a
> groove goes all the way through the cover, the engine coolant flows
> freely into the oilpan and does a number on your engine. The noise
> could very well be that. Especially if its accomanied by any of the
> following: a slight off-timing during startup/shutdown or acceleration
> and/or a "dieseling" during shutdown.
> I'm having my whole engine rebuilt (for other issues too) and I can
> recommend a great mechanic in Long Beach if you need one.
> Peace,
> Kyler[/color]
