Re: OT side by side comparison of two different propultion systems
mark_digital© wrote:[color=blue]
> OK, there's two identical helicopters. One has no tail rotor, and uses
> ram jets on the tip of it's blades. The other helicopter uses a piston
> engine and has a tail rotor. Both of them set out to do the same travel
> distance and lifting while stationary in the air. They both return.
> Which one used less fuel?
> Yes of course this is a trick question.[/color]
How can they be identical if one has ram jets and the other
has a T/R?
I'd be very interested in knowing how they supply fuel to
the ram jet engines on the tip of rotor blades.
Not sure what is meant by travel distance and lifting while
*stationary* in the air. Does this mean they really didn't
go anywhere?
EM
