Re: Oil Change
<thecarpenter333@yahoo.com> wrote in message
news:1154739929.457275.58700@s13g2000cwa.googlegroups.com...[color=blue]
>A mechanic who only uses Valvoline basically told me to use the maxlife
> (level two?) Valvoline oil in my 1995 Corolla. It says it's
> recommended for vehicles with over 75,000 miles. He basically said the
> standard Valvoline would do practically nothing to protect my car which
> has 153,000 on it.
> Is what he said really true, that as soon as an older vehicle such as
> this goes beyond 75K that one has to use this maxlife oil? Another
> mechanic who uses Mobile One never told me anything about an upgraded
> oil from Mobile other than the synthetic oils, which I am told not to
> use since this is an older vehicle and to use synthetic oil one has to
> have used them from the very beginning.
> My question is, if using Valvoline, is there a real danger in using the
> basic oil with 153K on my Corolla?
>[/color]
"Maxlife" oils are designed for cars which have experienced significant
engine wear or have other related problems that can cause oil consumption
in-between changes. Obviously, this event does not magically occur exactly
at 75,000 miles, and on some cars that have been always used a quality full
synthetic, it may never occur.
There is no danger of using conventional oil on an older car, so long as the
viscosity is appropriate, your oil level is full (or nearly full), and your
oil pressure is normal. On cars with high mileage, it is sometimes
appropriate to use a slightly higher viscosity, to allow for excessive
engine wear.
