Originally Posted by Smittay
cool
it sounds like its coming from the engine though
it also idles around 1 1/2, is that normal??
It idles at 1500RMP? That is waaaaay too much idle for that car, I have a 05 S and when in park it idles at 800RPM and when in gear around 500-600RPM..... I am not mechanic here but I think idle should be no more that 1000RPM tops and for a properly maintaned and working engine that should be all it needs, I would def have a dealer look at that, 'cause if what you are describing is what I think it is it may be a problem with fuel delivery, like bad injectors or dirty filter or something like that is my guess....
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
