Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Ping Ray - the sequel
View Single Post
Old 08-05-2006, 12:14 PM   #10 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Ping Ray - the sequel
On Fri, 04 Aug 2006 17:01:56 -0400, Wickeddoll wrote:
[color=blue]
> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
> news:1f798$44d3acf8$44a4a10d$23690@msgid.meganewsservers.com...[color=green]
>> "Wickeddoll" <wickeddoll1958noeffingspam@yahoo.com> wrote in message
>> news:eavrhk.3ck.1@news.evilcabal.org...[color=darkred]
>>>>>>> Lately, my Echo has been making a wumpa-wumpa sound at higher speeds.
>>>>>>> I thought it might have been the one tire that I know is bent (They
>>>>>>> said it didn't need immediate replacement), but it seems to be
>>>>>>> getting louder. Could it be the compressor, since my A/C is on full
>>>>>>> blast most of the time? Or is it probably something costly. That
>>>>>>> 2000 car still has its original exhaust system, so I thought that
>>>>>>> might be it as well. Toyotas are great, but their exhaust often
>>>>>>> sucks. Gas mileage is still pretty damned good (31 mpg city despite
>>>>>>> the full speed A/C).
>>>>>>> Your thoughts?
>>>>>>> Natalie, bracing herself.
>>>>>> Without hearing the sound, it is difficult to determine the source,
>>>>>> but cars generally make wumpa-wumpa sounds for several. Possible
>>>>>> causes are a broken belt in a tire, bent wheel, bad wheel bearing, bad
>>>>>> constant velocity (CV) joint. The sound will always be related to
>>>>>> vehicle speed rather than engine speed if one of those are the cause.
>>>>>> If the wumpa-wumpa sound is coming from the car while it is sitting
>>>>>> still, check the back seat.
>>>>>> Check the tire for any unusual lumps or bulges because a blow that is
>>>>>> hard enough to bend the wheel can easily breaks an internal belt in
>>>>>> the tire. If the sound is getting louder, the internal tire damage may
>>>>>> be getting worse and is very dangerous because it can blow out. A
>>>>>> broken belt is often but not always detectable visually. The easiest
>>>>>> way to check whether the tire or the wheel is the cause of the sound
>>>>>> is to mount the spare and see if it goes away.
>>>>>> Whatever bent the tire could also have bent the tie rod that connects
>>>>>> the steering rack to the front wheels, bent a control arm, damaged the
>>>>>> axle or CV joint.
>>>>>> An failing AC compressor will generally make a whining and groaning
>>>>>> sound, not a wumpa-wumpa sound (ducking for the fwap), and using the
>>>>>> AC tends to prolong its life rather than shorten it because the oil
>>>>>> that is mixed with the refrigerant keeps things lubed better and keeps
>>>>>> seals from drying out.
>>>>>> A failing exhaust system just sounds loud and the sound is related to
>>>>>> engine speed, not vehicle speed.
>>>>>> So, bottom line, try the spare and see if it goes away. If it does,
>>>>>> do not re-mount the bad tire/wheel until you can get a replacement.
>>>>>> Good luck!
>>>>>> Ray O
>>>>> Ah, thanks!
>>>>> I'll take it in tomorrow - you've effectively scared the crap outta
>>>>> me...
>>>>> Natalie
>>>> Also, look for uneven or unusual tire wear because the car probably
>>>> needs an alignment after the wheel strike.
>>>> Good luck!
>>> Bad bearings - need replacement at $500!
>>> *sigh* so much for the extra income from my second job...
>>> Natalie
>>>[/color]
>> If you get service department mailers from your local Toyota dealer, look
>> for a "customer's choice" xx% off any job. On a bigger job, that can add
>> up.
>> That sounds a little high for wheel bearings, - crying sometimes helps to
>> get the price down ;-)
>> Ray O[/color]
> They say it's all the bearings and something about 'pressure mount' - Greek
> to me.
> Bend over!
> Natalie[/color]
Just go in wearing that bikini top you WON'T show US!!!!
(running and ducking!!!) ;)
