92 Camry V6 3.0
Please help,
My 92 Camry V6 3.0 has failed emission test twice for the same resaon,
which is low HOx/252 ( standard should be around 937) and high HC/180 (
standard should be around 124) and high CO%/3.52 ( standard should be
around 0.69). Prior to emission test I have repaird the following
I have new Timing belt, spark plus, wires, 2 main belts, radiator,
radiator cap, water pump, thermostat, power steering pump, power
streering high pressure hose, lower engine mounts, sway bar bushing,and
PVC valve
