Every thing here that I'll be typing is right out of the official Toyota repair manual. I my self didn't follow some of these steps because I had already stripped all the interior as well as many other parts by this point. Though I may have inadvertently folowed them. :o
Removal of sun roof:
1. Disconnect battery cable from battery.
2. Remove center cover of control box.
3. Remove control switch.
4. Remove motor through service hole.
5. Remove wind deflector.
6. Remove guide rail cover
7. Remove sliding roof and guide rail.
(a) Apply adhesive tape to protect the body.
(b) Pull the sliding roof with the guide rail upward to remove.
Dissasemboly of sun roof:
1. Remove sliding roof headlining.
(a) Pry off the clip.
(b) Pull the sliding roof headlining rearward to remove.
2. Remove guide rail and cable guide casing.
(a) Loosen the screw.
(b) Pull the guide rail rearward to remove.
(c) Pull the cable guide cassing to remove.
3. Note the number of shims on the front and back.
4. Remove the front shoe.
5. Remove drive cable and rear shoe.
6. Remove drive cable from cable casing.
Removal of sliding roof panel:
1. To remove only slyding roof panel.
(a) Pull loose the clips and slide the headlining rearward.
(b) Remove the front and rear shoe bolts.
(c) Remove the roof panel.
1997 Corolla SD sold __________________ 1986 Corolla GT-S liftback *Christine* R.I.P.
1986 Corolla GT-S liftback *Ashley*_____ 1986 Corolla GT-S coupe *Martha* R.I.P
2005 Impreza RS 2.5
