Originally Posted by hsakuragi
the dealership was right, it should be CHANGE every 30k, then flush at every 60k
Generally, It is recommended to stay away from a flush. The additives that they use when they flush will often stay in the transmission and cause further problems. As long as you change the fluid (Drain and refill with a new filter) every 30k or so, you will be fine.
It really isn't too hard to change yourself. First time may take a full afternoon, but all you need is a socket set, a jack/ramps, Fluid and Filter. You will easily save yourself $50 or more.
Flushes are something that a lot of places use to make extra money, they don't really offer a benefit.
