Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 92 Truck Wont Idle
View Single Post
Old 05-01-2003, 08:02 AM   #6 (permalink)
WKOBE88822
View WKOBE88822's Photo Gallery
wont run
this may sound silly but i found info on this problem then eletrical wiring for the brake lights maybe causing this problem here is what i found
The EFI computer receives a signal from the brake circuit that tells it that the brakes are being applied. This causes the computer to shut off the injectors if the RPM's are over a certain level and the engine is in "closed loop" as engine power should not be needed if the brakes are being applied.I believe the set point for the injector cut out is 850 to 900 RPM. This is what causes the surging - your idle RPM is too high, when the brakes are applied the injectors are cut out until the RPM's drop below this level. The engine then run's again. This only happens when the engine goes into "closed loop" so this will not happen when the engine is at a higher idle speed warming up. I am willing to bet your idle speed is around 1000 RPM when this happens. To fix this problem, simply adjust your warm idle speed to 750 RPM as per the factory.
WKOBE88822 is offline
