Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Calling out to fellow HID retrofitters for assistance
View Single Post
Old 08-18-2006, 12:13 PM   #9 (permalink)
Hawkeye-SE
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
Fantastic. I used 4 bolts to secure mine to the reflector. No springs. Adjusted them so that I could use the factory aiming mechanism. Then epoxied the nuts on so they wouldn't move. Basically just get them aimed right horizontally and rotationally, then use the factory adjusters to adjust them vertically.
I used A4 shrouds. I roughed up the chrome trim piece on the TSX projectors and epoxied the shrouds directly to the projectors. This was the easiest way I could see to do it. If you are use standard A4 shrouds you will have to enlarge the opening slightly. And be VERY careful with the chrome I destroyed 2 sets of shrouds by flaking the chrome off.
Good luck. Def post pics of the final result.
Hawkeye-SE is offline   Reply With Quote
