so, 4 bolts to the back of the reflector? or all the way through the reflector and to the back of the housing? Did u guys use any kinda plastic peice so that the bolt would be flush with the reflector curve? like some peice of plastic or whatever that looks like |===\ and \===|
Still debating on which method to use. And... how deep should the projector be inside there? Kinda worried the side distance would be cutoff if I shove it too far in.
And also, I kinda noticed a slight gap of like 1mm between the two peices of the projector, dunno if I should worry about light leaking outta there. Slightly more gap on the bottom (2mm?) now since i added some washers on the bottom
2002 Camry LE I4 4AT
Spoiler, front strut bar, 17" wheels, Viper 791xv remote start alarm, Injen SRI, 50%-15% tint, TRD Exhaust, Tein S-tech, NST pulleys(underdrive + accessories), Whiteline RSB, HID+TSX projector retrofit.
2007 Nissan 350Z Grand Touring 6MT w/ Navi
