Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Possible to have 15" tires on Camry 2007?
View Single Post
Old 08-22-2006, 01:59 PM   #14 (permalink)
pjp
pjp's Avatar
View pjp's Photo Gallery
Canada 15" steelies
Originally Posted by Joe B
I wouldn't do it.
I think you'll have a problem with your tire air pressure monitoring system.
Possible warranty issue also.
AFAIK Canadian 2007 Camrys do not have a Tire Pressure monitoring system. Not even the XLE. I think you just have to make sure your brake rotors will not rub on the inside of those 15inch tires.
I don't know if ABS would be an issue as long as you replace all 4 tires or that they all have the same outer diameter (OD).
07 Camry SE I4 auto
pjp is offline   Reply With Quote
