Re: Does anyone here Service thier own A/C?
On Thu, 24 Aug 2006 23:55:45 GMT, Hachiroku <Trueno@ae86.gts> wrote:
[color=blue]
>Yeah, believe me, I read the instructions, and then took a half an hour
>tracing the tubing to determine the Low side!!
>On the LHS, it's easy...the caps are marked "H" & "L"...
>I still shy away from those cans, though![/color]
If it's only the caps, I would NOT count on that - they could easily
have been placed back on randomly on a R-12 car, they are both 1/4
Flare ports.
This is why R134 ports are two different sizes - the low-hose will
not go on the high port, and vice versa.
The other big thing on a R12 retrofit is the compressor oil - R12
uses Mineral Oil. For R134 you need to flush 99% or so of the mineral
oil out and install a fresh charge of synthetic POE or PAG based oil.
Or the oil reacts with the refrigerant and turns to pudding, and you
know the rest...
--<< Bruce >>--
