Re: Failed Emission Test
"kenny_frohlich" <kenny_frohlich@yahoo.com> wrote in message
news:1156685499.120084.18320@74g2000cwt.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> news:1156631451.671884.51450@i42g2000cwa.googlegroups.com...[color=darkred]
>> > Hi All,
>> > I took my 93 Corolla in for an inspection last week and it failed the
>> > emission test. The NOx levels both for high speed and low speed were
>> > high. I then took my car to a shop to get the catalytic converter
>> > replaced. However, when I went back to the inspection station to get
>> > it re-inspected yesterday, not only it still failed, but the failing
>> > levels were even higher than the first inspection. Can someone please
>> > tell me what the problem is?
>> > Thanks,
>> > Kenny
>> >[/color]
>> What are the other readings for the emissions tests, ie., Hc, CO?
>> I would check EGR and MAP sensor operation, depending on the results of
>> the
>> test.
>> Ray O
>> (correct punctuation to reply)[/color]
> Ray,
> Other readings are passing and they are:
> HC: 22
> CO: 00
> CO2: 13.5
> O2: 1.3
> Dillution: 13.5
> By the way, I know the EGR valve looks like a flying sauce thing, but I
> can not seem to locate it under the hood. Can you please tell me where
> I can find it (This is a 93 Corolla)?
> Thanks,
> Kenny
>[/color]
This California Smog Check web site lists common causes for emissions
failures: [url]http://www.smogsearch.com/index.php?page=faq[/url]
A lean mixture could be due to a bad O2 sensor or clogged injectors. Check
ignition timing to make sure it is not too advanced (are you getting any
knocking/pinging on acceleration?)
Not all vehicles have an EGR valve. I don't recall if yours does nor not.
The EGR valve is generally located near the intake manifold with a pipe
leading to the exhaust manifold.
Ray O
