Tool for Axel removal
The quick pop is what was needed as you stated. Autozone has a tool for rent (actual 2 tools) that is for removal of the drive axles. What you get is a slide hammer type puller and an attachment that screws onto the end of the slide hammer that looks like the letter "C". The "C" slides up behind the axle where it goes into the transaxle and a quick pop or 2 with the slide hammer and the axle comes out. You either need someone to support the outer of the axle so it is rather straight or put the outer of the axle on a wood block or something. All tools at Autozone are freee to rent (charge your credit card and the refund to credit card on return) The tool saves on having to grind on your crow bar and other improvisations.
Tony
