Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - replacing '92 Camry driver door handle?
View Single Post
Old 09-03-2006, 11:15 AM   #5 (permalink)
profuse007
Gameroom cash: $133300
View profuse007's Photo Gallery
to remove the door panel
1. remove int handle trim. insert a flat at teh pivotal point of the lock and latch.
2. remove all hardwares holding the panel
3. pop off door panel from under.
to remove the ext handle
1. reach up and pop off two rod clips(latch and lock/unlk) from the ext handle. clips are very fragile
2. unbolt two 10mm holding the ext handle. youre done removing!!!
post your result some pics.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
