Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 92 Camry I4 - did timing belt, now it doesn't start
View Single Post
Old 09-10-2006, 06:57 AM   #10 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally Posted by JPaganel
I'll recheck the timing. If I'm looking at the distributor and the timing mark is at 0, where should the rotor point?
With the crank at 0 and cylinder #1 at TDC on compression stroke, the rotor should point to #1 (left most cylinder, the one closest to the belts).
You may have to rotate the crank more then 1 turn. 720 degrees (2 revolutions) of crank rotation = 360 degrees (1 revolution) of cam rotation.
"Skoolin' the unlearned!"
