the HVAC controls are held in by 4 clips... you will need a flat bladed tool (screwdriver, spatula, whatever works) to pry it up. then there are two bulbs in the back, use a screw driver to "untwist" the bulb and it should come out. replace and reverse.
you should also check out the stickies in General Camry Discussion, very useful. especially this: http://www.toyotanation.com/forum/t132391.html
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
