Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Budget Turbo-again
View Single Post
Old 09-13-2006, 06:29 PM   #9 (permalink)
punter
The TN Member
View punter's Photo Gallery
The ECM will see boost with a 2 bar map, but none of the table will be calibrated properly. The map sensor measures load, the main transmision, fueling & timing controls are all based on load. Basically the most of ECM tables would need to be completely redone for it to work right.
Twice the injector won't work, I guarentee it won't even idle with that.
Then you better get in touch with this guy and tell him the car he drives everyday without a problem, infact runs like shit and doesn't idle.
http://forums.toyspeed.org.nz/viewtopic.php?t=31816&
If it doesn't work then how come it works fine for this guy?
Got any proof to backup your claim? Ever tried it? Or are you just making stuff up?
Say no to huge pics as signatures.
punter is offline   Reply With Quote
