Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - No sound from stero
View Single Post
Old 09-15-2006, 02:32 AM   #5 (permalink)
cam2Xrunner
cam2Xrunner's Avatar
Originally Posted by rayinpa
My 91 camry v6 le's stero will turn on but you can't hear any sound and the antenna does not go up. Thanks in advance for any help or advice.
Ray
Is it the stock one? Does it work with tape('91) .....need more info
If it works with a tape then your problem is an antenna problem.
You might need to replace the Antenna MAST or the motor. When you first turn the car on with the radio on do you hre the motor trying to raise the antenna? If you do then you most likely need to replacew the mast.
If you hear nothing you may need to replace the motor or you could possibly have a short in the antenna turn on wire(unlikely) or the radios antenna turn on ciruit is faulty(again unlikely)
