Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - How to verify a coolant flush?
View Single Post
Old 09-16-2006, 07:14 PM   #10 (permalink)
toyotaspeed90
Gameroom cash: $134355
Originally Posted by alltracman78
The point of the chemical is to clean it BEFORE you need it.
Same for any other flush.
To maintain the system correctly, you clean it BEFORE it NEEDS to be cleaned.
Same thing with oil. You change it before it NEEDS it.
comparing an oilchange to using an injector cleaner to get a better spray.... or a chemical cleaner in the radiator to remove rust..... or an engine flush..... isn't exactly the best comparison
oil degrades... but almost never would I reccommend using an engine flush (at the most maybe a quart of dex 3 to help a sticky ring... but that's generally after the fact that something bad has happened).....
if it's to the point where MOST people think they need to use a "magic cleaner" then it's usually too late.....
