Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Noisy disc brakes
View Single Post
Old 09-16-2006, 11:57 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Noisy disc brakes
<timagine@hotmail.com> wrote in message
news:1158413550.019045.63800@b28g2000cwb.googlegroups.com...[color=blue]
>I should have mentioned that the sound stops when I apply the brakes.
> voice from the past
>[/color]
Same advice applies.
Ray O
[color=blue]
> Ray O wrote:[color=green]
>> news:1158337995.087671.262750@b28g2000cwb.googlegroups.com...[color=darkred]
>> >I just had a front-end brake job: turned the rotors, pads... There is a
>> > fluttering sound on the left brake when I'm driving along.
>> > What causes this and how can I fix it?
>> > voice from the past
>> >[/color]
>> It is difficult to diagnose sounds without hearing the sounds, but here
>> are
>> some common causes of brake sounds that occur when the brakes are not
>> applied:
>> Improper rotor installation - fix by removing the rotor and installing
>> correctly
>> Improper pad installation - fix by removing the pads and installing them
>> correctly
>> Aftermarket parts, particularly pads, that do not fit correctly - fix by
>> installing OEM pads.
>> Stuck caliper slide - fix by cleaning up the slide, the slide bushing,
>> and
>> lubing with anti-seize, wheel bearing grease, or caliper slide grease.
>> Improper wheel installation or torque - fix by removing and reinstalling
>> the
>> wheel and torquing the lug nuts properly
>> Bad wheel cover - fix by installing a new wheel cover.
>> Ray O
>> (correct punctuation to reply)[/color]
>[/color]
