Originally posted by REN69
the engines on the AE86 GTS are pretty much the same as the 88-89 AE92 GTS.. the 90-91 AE92 GTS had a Higher compression engine, so I assume the internals are a bit different (hi-comp pistons, etc). the Hi-comp engine also had no TVIS which means there was no AFM, instead the engine had MAP i think.
nope even the smallport has afm. all 4age's on toyotas on our shores come with afm.
everything on the ae92 4age is on the opposite side...so to transfer it over would be a bitch.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
