Re: "Better" intake on '90 Celica?
On 18 Sep 2006 03:44:20 -0700, [email]omnineko@yahoo.com[/email] wrote:
[color=blue]
>The transmission was rebuilt about three thousand miles ago. As far as
>the engine, it has less than 150k miles on it.
>I'm not exactly looking for a BIG increase, just a noticable one. It
>can be a little scary sometimes to try and hop on the freeway when it
>takes what feels like half a minute to reach 70 MPH. ;)
>Coyoteboy wrote:[color=green]
>> Ray O wrote:[color=darkred]
>> > All other modifications are going to be marginal.
>> > Ray O
>> > (correct punctuation to reply)[/color]
>> I have to agree with you on this one. Unless you have totally
>> overhauled the rest of the gear and know its all in top notch
>> performance, and you remember to install the correct sized filter into
>> a cold-air-fed location while properly considering the road grime that
>> gets thrown up you will just lose power as the stock intake isnt that
>> bad. When i installed a K&N replacelent filter panel (direct swap, kept
>> stock intake gear) i saw an average of 0.5-1mpg increase over about 10
>> tanks on the standard car setup. I also saw this with a peugeot i ran
>> one on, but i did have to spend $50 on piping to get the filter to a
>> protected and cold intake location lol. Unless its fairly highly
>> modified id stay standard TBH.[/color][/color]
As you've heard from others, the increase wouldn't be significant
enough for you to notice.
I say this with consternation but perhaps you should look into
nitrous. It's cheap and can really make a significant difference. I
warn you though to be very conservative with it as it may prove
detrimental to an old engine designed for fuel economy and not for
drag racing.
For more reliable power, look into a header and cat-back exhaust
replacement. Make sure to purchase a high quality header. Cheap ones
crack on Toyota engines (due to high heat I think).
