Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Overdid it today!
View Single Post
Old 09-19-2006, 10:37 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Overdid it today!
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:k881h252cskv3oo924va23r82u816lctbv@4ax.com...[color=blue]
> On Tue, 19 Sep 2006 11:17:21 -0500, "Ray O"
> <rokigawaATtristarassociatesDOTcom> wrote:[color=green]
>>news:3ltug214940q3tru6d9umh7rat3k2de2b9@4ax.com...[color=darkred]
>>> On Mon, 18 Sep 2006 15:19:15 -0500, "Ray O"
>>> <rokigawaATtristarassociatesDOTcom> wrote:[/color][/color]
>[color=green]
>>The oil-less compressors were just coming out when I got my compressor
>>around 20 years ago, and since they were so new, I stuck to conventional
>>(at
>>that time) oil-lube compressor. I use my compressor quite a bit for
>>everything from blowing off the lawnmower to filling tires to air tools.
>>The only thing I don't like about the compressor is the oily mess when I
>>drain the tank.[/color]
> So put a hose on the tank drain and aim it into a bucket of kitty
> litter. The water evaporates and the clay absorbs the oil nicely for
> easy disposal.
>[/color]
Great idea! I'll have to raise the compressor a bit so that I can get
something larger underneath the compressor, but there should be a lot less
mess.
[color=blue][color=green][color=darkred]
>>> If you have the room, get a belt-drive "old-style" unit with the
>>> horizontal tank, the slower compressor RPM adds to the longevity. The
>>> direct drive 1725 RPM units are a lot noisier, too.[/color]
>>Does the horizontal tank have an advantage over a vertical one or are you
>>talking just about the belt drive configuration? BTW, how long do those
>>belts last? I've never done any maintenance or repairs to the compressor
>>other than draining the tank and refilling the oil.[/color]
> I was talking about the belt between motor and pump. For small
> units with the 14 to 20-gallon tanks, they're usually horizontal.
> Belt drive lets them use a more efficient 3600 RPM motor and gear it
> down with the pulleys for a compressor head that would rather see 600
> - 900 RPM for long life and better volumetric efficiency.
> Direct drives have to run the compressor head at either 1800 or 3600
> RPM in lock-step with the motor, which is not the preferred way to go.
> You have to go with smaller pistons and/or shorter crank throws, and
> it's harder to dissipate heat.[/color]
When you explain it that way, it makes a lot of sense.[color=blue]
>>>>The plastic cover on the trigger for my impact gun broke off so it kind
>>>>of
>>>>hurts to use my impact gun. It was a free sample and still works, but
>>>>now
>>>>I have an excuse for a new one!
>>> Depending on who made it, those molded rubber grip sections are
>>> available as replacement parts. Or go get a set of the special
>>> "anti-vibration" gloves with the gel pads in the palms and
>>> second-knuckle areas of the fingers.[/color]
>>The brand name on the gun is Fuji, which I've never heard of here in the
>>U.S. I got it from my dad, who says that company supplies them to
>>factories. The guns supposedly can be calibrated to apply accurate torque
>>over many uses. The instructions were in Japanese and I never bothered to
>>ask someone to translate for me. I like the gun because it is
>>relatively
>>light and it doesn't over-torque alloy wheels. I don't like the gun
>>because
>>it is relatively gutless at removing stubborn bolts that someone with one
>>of
>>those monster impact guns torqued.[/color]
> Time to do a web search for Fuji, finds a parts list, and order one.
> You can get a new monster gun for doing lug nuts and crank pulleys if
> you want, but there are times when finesse beats brute strength.
>[/color]
Hmm, looks like an outfit in NY imports them. Time for more research...
[color=blue]
> Plus, Murphy's Law says the tool breaks 5 minutes after you could
> possibly get to the last store in the area that sells them before they
> close - and the car HAS to be on the road tomorrow morning...[/color]
True, plus, one cannot have too many tools!
[color=blue]
>>> 90 CFM? Refer to that Body Shop above, with the twin 15 HP units....[/color]
>>Oops! typo! I meant 9 CFM.[/color]
> Yeah, Right, Suuuuuuuure ya did... ;-P[/color]
Well, more of a brain fart than a typo.
[color=blue]
>[color=green]
>>My compressor is Craftsman brand, listed as 220V, 5 HP 30 gallon single
>>stage. I don't know who made it. It is fine for air ratchets and impact
>>guns but it runs quite a bit when I use a cutoff tool or die grinder.[/color]
> If you have a "5 Sears Horsepower" unit, it is probably a 2-HP or
> possibly a 3-HP unit - check the nameplate for the running amps to
> divine the true HP ratings. Sears has had to correct their
> literature, electric motors are supposed to be rated at Full Load
> Current, not the bigger and more impressive sounding Stall Current
> rating Sears wanted to use...
> According to the NEC, 2-HP is 12A at 230V. 3-HP is 17A at 230V,
> 5-HP is 28A at 230V for a single-phase motor. Real 5-Horse units need
> a magnetic motor starter, the pressure switch contacts can't switch
> that much juice reliably.
> Look at the motor nameplate and Century Electric Motors refuses to
> lie about it, they just mark the HP Rating box as "Special" - any HP
> claims made are not theirs.
> --<< Bruce >>--
>[/color]
Yup, as usual, you were right. The motor is GE, 13.1 A at 220 V. The
compressor is rated at 12 CFM at 90 PSI.
I know that Sears has a tendency to over rate their lawn mower HP, it makes
sense that they would do it for compressors. Oh well, it is good enough for
my needs most of the time.
Ray O
