Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - high altitude and carburater
View Single Post
Old 05-13-2003, 01:26 AM   #2 (permalink)
rezzle
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
It shouldn't be too much of a problem as the amount of gas in a carburetor is metered by the venturi effect through the carburetor. With thinner air the mass flow rate of the air through the venturi becomes smaller and so does the amount of gas being metered. If anything you may run a bit rich (too much gas) but running rich is just unclean. It shouldn't do too much damage to your vehicle other than an occasional fouled plug. I would only consider a change to the jetting if you actually saw black smoke coming out of the exhaust (unlikely)
You are truly better off not leaning out the carburetor if it does run rich because when you decide do drive to lower altitudes with small jetting you could wind up running lean (not enough gas). Running lean is hard on an engine as it will cause it to overheat and even possibly seize.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline
