You wont get all the oil out if you jack the front of the car up, just a little tip. If you look at it, the oil plug IS the lowest part, atleast thats how its on my car.
And make sure the engine is at operating temp when you change the oil.
This helps get rid of more of the contaminates [they are suspended in the oil instead of sitting at the bottom of the pan].
And half of the oil with the contaminants is in the head area, plus you'll burn yourself with the hot oil... The particles are most likely gonna be lighter than the oil, so they'd float in it, its not like you're gonna have sand or metal chunks in it.
