Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Exhaust
Thread: Exhaust
View Single Post
Old 09-21-2006, 09:50 AM   #12 (permalink)
Beemik
View Beemik's Photo Gallery
these are the parts i bought from ebay
header+flexpipe
obx high flow cat(look in one end and see out the other, no honeycomb, catalyist is on walls)
greedy style n1 catback(tsudo exhaust)
Like was said in prev post the catback has place for other sensor i used the plug from the header to plug the hole in the catback!! perfect fit.
the obx cat shown is for a acura i think but it is very similar to the one you can purchase and the one i did purchace.
i had no fitment issues with any of the parts except the catback seems to sit a little low. there are no brackets to pull it up so im thinkin on putin a bracket on to bring it up some
notice how i didnt burn in the header properly. a very spotty uneven burn looks like shiiit. but is fixable if you want to get out the metal polish, then wash then idle the car for about 20min or until fan kicks on. then get on the highway and do 120km/h or about 70mph in third for about 2min. you will then get a nice even blue, purple and gold burn in. I work in a machine shop and had one of the metelergests look at the steel he said it is a high grade stainless.
yull hav to pardon the pics they were taken with a v710 camera phone
this is the obx highflow cat. i notice i get some deep vibrations at around the 2800rpm mark if i try to gas it. it sound as though its comming from the cat and resonator area but could be the lack of support on the catback im not sure.
this is where the catback sits a little low
the cap in the pipe comes with the catback. the large hole in the end is standard. i had to put the cap in the drill press and drill the smaller holes because it wouldnt run with just the one hole in the centre. i had no power. put the gas to the floor and it wanted to stall. sit at a light and it wanted to stall. i took the cap off and it sounded like shiiiit. its a high flow muffler so its straight through without the cap there is not much muffling goin on. there is a pipe from the large hole in the centre of the cap that goes back into the muffler i also cut this short and drilled some holes in it.
The full exhaust does sound a little airy when at idle or low rpm but when you hit the 3400rpm mark and higher i think it sound pretty good. you will notice that the car does idle a little lower but that is due to losing alot of back pressure. after i put this full system on the car i went and picked up my girlfriend and i punched it at the same set of lights i alwas punch it as when pickin her up. i reved to the same 6000-6200rmp redline i always do and she said " why does the car seem so much faster " she made me smile and say " its suppose too "
just thought this might help u decide.
Beemik is offline   Reply With Quote
