Re: Got a couple questions about my 92 4x4 PU
The binding happens because there is no differential between the front and
back wheels. When turning the front wheels take a longer path than the back
wheels so they have to spin faster (ie roll over more ground.). This is why
you never run in 4x4 on pavement, or any grippy surface for that matter, if
you did it would put a lot of stress on your transmission and 4x4
components.
HTH,
-Andrew
P.S. Have you checked with toyota about possible recalls on your truck?
You can email them your VIN through their website. Do it! Just this past
January I had them do my head gasket, steering rod relay and headlight
wiring all for free.
"Eric R Snow" <etpm@whidbey.com> wrote in message
news:1966h2dc0k233vi5ri52325tkp880munut@4ax.com...[color=blue]
> On Wed, 20 Sep 2006 22:59:29 GMT, "Mike" <mik@localnet.com> wrote:
>[color=green]
>>news:tr23h256fu5l8cfdhpmdiqnobbi80taspf@4ax.com...[color=darkred]
>>> Greetings All,
>>> I have a new to me 92 4X4 extended cab pickup with automatic hubs, 5
>>> speed, and the V6 engine. When in 4 wheel drive the wheels bind when
>>> turning at low speed. For example if I'm in a dirt parking lot making
>>> a fairly tight turn and moving at about walking speed the truck seems
>>> to bind. Like it wants to go straight instead of turning. And I can
>>> hear the back tires and front tires alternately slipping. I have been
>>> told that this is normal. Backing up in 4WD and turning does the same
>>> thing. After straightening the wheels but still moving backwards the
>>> wheels still seem to drag or bind. And the truck jumps a little. Once
>>> moving straight ahead this binding goes away. The truck rolls equally
>>> well straight ahead whether in 2WD or 4WD. Is this binding really
>>> normal?[/color]
>> Yes
>> The other question I have is about 1st gear popping out[color=darkred]
>>> sometimes. If I'm not careful the truck will pop out of first gear. I
>>> believe this is because it is not going all the way in to gear.[/color]
>> It may be an easy fix. Remove the shifter from the top af the tranny.
>>There are 2 bushings, one on the end of the shifter and another that the
>>shifter rides in. If either of these is broken it will cause the problem
>>you
>>have.
>> I[color=darkred]
>>> think the gear shift lever is not moving as far when this happens.
>>> Once in gear completely though it will not pop out no matter what I
>>> do. It only happens when I'm in a hurry and not really paying
>>> attention to how far I'm pushing the gear shift. Could this be an
>>> adjustment problem?
>>> Thank You,
>>> Eric R Snow[/color]
>>[/color]
> Greetings Mike,
> Thanks for the speedy response and the good advice. Since the binding
> is normal can you tell me why?
> Cheers,
> Eric[/color]
