Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - dark dashboard instrument panel
View Single Post
Old 09-24-2006, 12:00 AM   #3 (permalink)
planetcalculi
Guest
Posts: n/a
View planetcalculi's Photo Gallery
Re: dark dashboard instrument panel
Thanks for the suggestion, but that is not the problem.
: P wrote:[color=blue]
> have you checked the dimmer control switch. it may have be accidentally
> adjusted. I don't know exactly where it would be for your truck, so you
> should consult your owners manual for the location. look for the
> instrument/dash disgram and it should be noted.
> "planetcalculi" <one4all@pacbell.net> wrote in message
> news:1158985578.560253.175160@k70g2000cwa.googlegroups.com...[color=green]
> >I have a 2001 Toyota Tundra. About two days ago, I noticed that the
> > speedometer and other gauges will not light up. All of the other lights
> > on the truck, including the dome lights, bed light, running lights,
> > etc. work. I checked the fuses but none of them are burnt. Furthermore,
> > when the headlights are turned off, the radio is lit up. When the
> > headlights are turned on, the radio is not lit, but it still works. I
> > just recently had two keyless remotes reprogramed. Is it possible that
> > the service technician did something to the instrument panel wires? I
> > intend to take the truck to the dealer but I thought I would first ask
> > if anybody had expreienced the same problem and had a easy solution.
> > Thanks.
> >[/color][/color]
