Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - AE92 & AE82 Brake upgrade options....
View Single Post
Old 09-29-2006, 09:38 AM   #2 (permalink)
Flashmn
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
It is almost exactly the same for the AE82 EXCEPT where the AE92 demands that you replace the rear most suspension arm with the arm from disc-braked donor car the AE82 does not.
Sorta true, however, you can use AE92 rear calipers with the AE82 caliper bracket, that goes in between the hub and suspension arm. OR you can make your own bracket, so necessarily changing the suspension arm doesnt have to be done. I didnt do it, I thought its gonna be a shitload of extra work to do it. AE82 caliper has a 32mm piston as the AE92 one has a 30mm piston.
