Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 80 Toyota P/U 20R stalls when warmed up
View Single Post
Old 10-01-2006, 09:59 PM   #5 (permalink)
Lefty
Guest
Posts: n/a
View Lefty's Photo Gallery
Re: 80 Toyota P/U 20R stalls when warmed up
Mike K wrote:[color=blue]
> "Lefty" <mrsunbeam@cox.net> wrote in message
> news:1159730672.082545.136650@i42g2000cwa.googlegroups.com...[color=green]
> > Ernie Leimkuhler wrote:[color=darkred]
> > > In article <1159569862.407129.223370@b28g2000cwb.googlegroups.com>,
> > > "Lefty" <mrsunbeam@cox.net> wrote:
> > > > I've had an on going problem for the last two years and my forehead is
> > > > getting sore from banging it against the dashboard. When my 80 Toyota
> > > > P/U with a carburated 20R warms up it starts running rough and stalls
> > > > the minute I stop. I've been through just about everything including
> > > > unhooking hoses and valves one at a time to see if it makes a
> > > > difference on top of rebuilding the carb twice. If this is a EGR
> > > > problem, is there a way to eliminate it from the system safely or a
> > > > place I can acquire one for a reasonable price? Thank you for ANY help
> > > > in this matter, Sincerely Lefty
> > > Sounds like a choke problem on your carb.
> > > Like the choke isn't opening as the engine warms up.
> > > Takes the air intake cover off and watch the choke as the engine warms
> > > up.
> > > The choke is the flapper at the top of the carb closer to the passenger
> > > side.
> > > As the engine warms up the choke should go from mostly closed to mostly
> > > open.
> > > If it is the choke, you can either have the choke unit replaced by a
> > > carb rebuild shop or just buy a new carburetor.[/color]
> > No, its not the choke. Been there done that. The choke works great, in
> > fact if the choke where to stay on all the time it wouldnt stall. If
> > you put your hand over the carb after it is warmed up and stalling the
> > idle will come up a stop it from stalling. Yes, I know it sounds like a
> > vacuum leak. I've been there and done that two. Thats why its still
> > doing what its doing after two years of trying everything this side of
> > replacing the EGR. Lefty
> >[/color]
> Does the carb have a solenoid for on the side of it?
> My 79 had a broken wire going to the idle fuel solenoid, engine would run on
> choke or very high idle setting but would stall if I tried to turn the idle
> down below 1600 rpm. Mike[/color]
Yes it has a deceleration solenoid and the vacuum switch that engages
it is bad but, engaging the solenoid manually has no effect on it what
so ever and I did make sure it does work, the solenoid that is. Some
times it runs rough and stalls when cold but, mostly after it s warmed
up. That's why I believe it may be a EGR problem, sticking or opening
too far. Its just a real big hassle to get the thing off being its not
designed the same as most. That's why I'd like to have a second opinion
before bang knuckles. Lefty
