Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Suggestions on what to ....
View Single Post
Old 08-03-2001, 11:01 AM   #14 (permalink)
Gruven
View Gruven's Photo Gallery
You can't so much as compare them to driving with your highbeams because the beam pattern would be different and they cover a different area than the lowbeams would. But as far as brightness goes, it's MUCH brighter than highbeams. Highbeams look bright because they're basically aimed at your face when you look at them. Plus, the light produced is a much cleaner white than the conventional light. The clean white is what those "imitation" HID Xenon bulbs try to produce. The problem with those is that in order for the light to be as white, a bluish film has to be placed onto the bulb's surface to filter out the blue. Now, by putting *anything* on top of the bulb's surface, no matter how translucent it is, you're blocking light from coming through. That's why those Xenon lights are dimmer than your conventional lights. Just run a comparison between the standard lights and say, PIAA's. You'll see that the light area produced by PIAA's are, although cleaner and whiter, is much smaller than the conventional lights.
Just some food for thought..
On 2001-08-02 19:05, Ratko wrote:
damn, thats what im talking about !
definitely on my todo list... saw it somewhere in markham (phillips aswell) for i think 800-900 CAN.
how much more luminescent are they? it may be a dumb question but are they comparable to driving with your high beams on? do they light up just as much as your original high beams ?
thanks.
Gruven is offline   Reply With Quote
