Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Running too RICH
View Single Post
Old 10-08-2006, 02:25 PM   #10 (permalink)
rppta
View rppta's Photo Gallery
When engine was in 91 before crash it was running without problem avg 24mpr. Moved engine to 92 used only block and head only swaped all 92 parts onto 91 including dist, injectors, intake etc. Checked timing and set as outlined in Haynes Manual. Got check engine light and code of 3 1. Haynes said MAP sensor which I ordered new and changed. Discon battery and removed fuse as per instructions in manual and check engine light came right back on. Again checked code and again MAP sensor. By the way drove 91 car after crash and it did run well.
rppta is offline   Reply With Quote
