Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Hey 88LE, you ever installed a remote starter in a camry?
View Single Post
Old 01-08-2002, 07:10 PM   #4 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
On 2002-01-07 21:58, critikal wrote:
Thanks man and if it helps, Ive figgured out that the light comes on when I remote start the car, put the key in so I can drive it, and then when I go to put it into gear, the light comes on. The weird thing is it only comes on about 1 out of 5 times, but then it stays on.
Weird.
I really dont think it would matter but theres two 12 volt constant wires that go into the remote start, I ran them both to the same 12 volt constant wire at the ignition harness (the white one wire) You think maybe I should run one to the white and the other to the white and red? Maybe its too much power for that one circuit (just a thought)
I don't think it matters since both wires (the ones at the ignition harness) are +12V constant and they go to the same source (the battery).
By the way my buddie is in Vegas for CES so I can't ask him if theres anything special you have to do to wire up a remote start module to a Camry.
"Skoolin' the unlearned!"
