Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Rubbing sound coming from front end.
View Single Post
Old 10-08-2006, 08:03 PM   #11 (permalink)
Clyde Hathaway
Guest
Posts: n/a
View Clyde  Hathaway's Photo Gallery
Re: Rubbing sound coming from front end.
I have owned two 1990 pickups and both of them made a rubbing sound when
turning sharp to the left, such as in barely moving forward. I also was at
a ball park one time and witnessed another pickup sound the same way when it
pulled out from the parking space. I have never been able to determine what
it was. There was a recall issued last year for a steering rod - mine was
replaced and I am not sure if the noise is still there or not.
Clyde in VA
"Hanke1" <chris_f@yahoo.com> wrote in message
news:1159984819.670229.136730@m73g2000cwd.googlegroups.com...[color=blue]
> Sounds like it could be the Wheel bearing or Spindle bearing. Have you
> tried lifting the wheel and holding the wheel at 3and9 o'clock seeing
> if there excess play?
> Noon-Air wrote:[color=green]
> > Check your brake discs for runout.
> > "grinder" <seagle@earthlink.invalid> wrote in message
> > news:L4RUg.4893$Y24.1992@newsread4.news.pas.earthlink.net...[color=darkred]
> > > "JoeSpareBedroom" <dishborealis@yahoo.com> wrote in message
> > > news:W4QUg.2263$ya1.792@news02.roc.ny...
> > >> news:HQPUg.3002$Lv3.250@newsread1.news.pas.earthlink.net...
> > >>> My '90 4Runner has developed a rubbing noise in the front end. At[/color][/color][/color]
first[color=blue][color=green][color=darkred]
> > >>> I thought it was a loose brake pad or foreign matter. I checked
> > >>> underneath and have not identified any foreign matter. And the[/color][/color][/color]
sound[color=blue][color=green][color=darkred]
> > >>> continues when the brake is depressed.
> > >>> - It is worse at first and seems to go away as the truck is driven.
> > >>> - The rubbing sound happens twice with every revolution of the[/color][/color][/color]
wheel.[color=blue][color=green][color=darkred]
> > >>> - It is coming from the front end.
> > >>> - It occurs if with the clutch in or out.
> > >>> - It occurs in first and second gear (by third gear it seems to
> > >>> disappear or at least is difficult to detect do to increased speed).
> > >>> I think I know what it is and am going to try to correct it today[/color][/color][/color]
but I[color=blue][color=green][color=darkred]
> > >>> don't want give my guess here because I don't want to influence any
> > >>> responses.
> > >> What happens if you coast down a hill in neutral, or (carefully) with
> > >> engine off?
> > > Sound does not go away with clutch in.
> > >[/color][/color]
>[/color]
