<tsingh@cnds.jhu.edu> wrote in message
news:1162331016.770469.160820@e3g2000cwe.googlegroups.com...[color=blue]
> Four years ago I bought a '95 Lexus ES300 that shifted very smoothly
> but had dark brown transmission fluid. I had the transmission
> power-flushed on a T-Tech machine and immediately thereafter the shifts
> became harsh and slightly erratic. Somebody suggested that dirt
> dislodged by the flush had probably clogged/damaged the valve body.
> Over the next 4 years I drained and filled the transmission a number of
> times, and each time shifts would get smoother for a few days. Last
> month I finally had it power flushed again, and this time there was a
> significant but temporary improvement.
> Does this sound like a valve body problem? If so, how hard is it to
> replace (with a remanufactured unit)? Is this something that can be
> done in a few hours by a non-professional without specialized tools?
> Thanks,
> Tripurari
>[/color]
I recommend that you do not power flush the transmission any more unless it
has been done routinely every 3 or 4 years since the transmission is new,
otherwise, you will have the problems that you are experiencing. If the
automatic transmission fluid is very black, then the most you should do is
drain and re-fill.
AFAIK, there are no OEM remanufactured valve bodies, only remanufactured
transmissions.
I doubt if replacing just the valve body would eliminate the harsh and
erratic shifting because the stuff that was dislodged by the power flush
could be stuck anywhere inside the transmission. My guess is that a new
valve body would cost in the neighborhood of $1,800 so that is a pretty
expensive part to replace without guaranteed success.
I would not attempt replacing a valve body without a factory repair manual.
I suggest that you look at the procedure and then you will have an idea of
whether it is something you want to tackle.
Ray O
