Re: How much pressure is in the transmission cooler hoses leading to the radiator
Mark wrote:[color=blue]
> I just replaced the radiator on my 95 Camry 4 cyl. I used new hoses
> for the upper and lower radiator feeds and 2 new hoses for the
> transmission cooler. I had a little trouble with the new transmission
> cooler hoses engaging them as far onto the fitting as I would like.
> The clamp is defnintly on over the bump in the fitting. I believe
> these hoses are not under high pressure.
> Is this correct? How much pressure is on the trany fluid that passes
> through the tranny cooler hoses?
> thanks
> Mark[/color]
