Re: How much pressure is in the transmission cooler hoses leading to the radiator
Ray O wrote:
[color=blue]
> Actually, "under 20 PSI" is just a guess on my part, I can check a factory
> service manual when I get home tonight. IIRC, the pressure going to the ATF
> cooler is much lower than internal line pressures, which is how I came up
> with 20 PSI.[/color]
You are correct about your pressure guestimate, the cooler circuit
pressure is regulated (reduced) in the valve body. I suspect you will
not find a spec on cooler pressure, but if you do let me know. The
only spec I have ever seen in any model/year Toyota RM is for line
pressure under various conditions.
Toyota MDT in MO
