Taking the Console apart:
1. Place car in neutral and set the e-brake (I realized I needed to do this when I got to step 5)
2. Disconnect negative terminal on the battery.
3. Remove both bottom side trims starting from the top (where Im pulling in the pic) and pulling outward towards the bottom where the shifter is located.
4. Using a Philips screwdriver, unscrew the 2 screws on either side of the dash bezel.
5. Remove the shifter trim by starting from the bottom and working your way up to the cigarette lighter compartment. Don’t pull it out all the way, just get the shifter trim out of the sockets its locked in to. Flip up the tray that has the cig lighter to make removing it easier.
6. Remove the white cigarette lighter plug from the back. Just push the clip in and pull it out.
7. Cigarette lighter plug removed.
8. Now you can pull out the whole shifter trim.
9. Open up your center storage console. Take your flathead screwdriver and pry up the area shown in the picture (I didn’t have a flathead so I used a carving tool :thumbsup
10. Lift up the cup holder console starting from the back and working toward the shifter. The whole thing is attached to the e-brake boot so it slides out of the e-brake. Nows also a good time to clean that damn e-brake boot too.
