Maintanence for 2009 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix General Discussion Forum A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 8 Old 11-29-2011, 09:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have the 2009 toyota corolla which I have been doing oil filter change every 7500 miles and a tire rotation.
I now have 30k miles on the car.
As many on this forum have suggested that the 30k,60k,90k mile service is a rip-off, please let me know what specific services I should get between now and 100k miles.
Thanks
kmurali70 is offline
post #2 of 8 Old 11-29-2011, 09:27 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3601 Post(s)
An easy way to do that is to use Toyota's Maintenance Guide to find out what are the recommended procedures, replacements, inspections, etc., for the different service intervals. Just enter your Corolla's information.
http://smg.toyotapartsandservice.com/guides.php
Ideal thing would be either to do the work yourself or have a trusted private mechanic do the work, which will be better and cheaper than any dealer.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline
post #3 of 8 Old 11-30-2011, 12:08 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1104 Post(s)
iTrader Score: 8 reviews
Thanks
I did all of the 30k mile service myself, no big deal. Change engine oil, change gear oil, rotate tires & check brakes & all fluids.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #4 of 8 Old 11-30-2011, 12:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Since I dont know how to check the liquid levels of misc ones, what I am asking is what should be the kinds of a la carte services I should be looking at and at what mileage ?
Examples
power steering flush
transmission flush
engine flush
brake fluid flush
and so on..and at what mileage should this be done.
Thanks
post #5 of 8 Old 11-30-2011, 01:32 PM
Do you feel lucky?
TrailDust's Avatar
Examples
transmission flush
engine flush
brake fluid flush
Thanks
Please click on the link in reply #2.
2002 Avalon XL
post #6 of 8 Old 11-30-2011, 10:24 PM
Diehard Rams Fan
Examples
transmission flush
engine flush
brake fluid flush
Thanks
Power steering is electric, no fluid.
Transmission fluid, drain & refill just like the engine oil.
Engine flush, not needed, just change the oil & filter.
Brake fluid flush. I was told to not flush the brakes, just bleed them very easy.
Manual will list milage to do each item in the maintenance area.
post #7 of 8 Old 11-30-2011, 11:13 PM
Senior TN Member
Quoted: 226 Post(s)
The transmission fluid supposedly doesn't have to be changed until 100k, but I find that BS. 30-50k intervals will extend the life of the transmission. The spec. fluid is Toyota WS.
Bleeding the brakes is easy, I would also do 30-50k interval. All you need is a helper to bleed the brakes, you don't even have to remove the wheels, just jack up the car.
pmesfun is offline
post #8 of 8 Old 12-01-2011, 03:49 AM
Diehard Rams Fan
I agree, the single best thing you can do to have a worry free AT is to change the fluid every 30k miles but removing the wheels will make it a lot easier.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix General Discussion Forum
User Tag List
Linear Mode Linear Mode
« Back
