DIY: Custom Dual Horn Install Cable (NO SPLICE!) - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix General Discussion Forum A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 23 Old 12-15-2011, 11:50 AM Thread Starter
Lowdown Lowlife
FlawedLegacy's Avatar
Quoted: 1 Post(s)
iTrader Score: 14 reviews
(Thread Starter)
So a lot of people have asked how I installed my horns without splicing at all.
Dare I say, one of the easiest mods and SUPER SIMPLE to make this custom cable!
*Sorry for crap night time pics with my droid. Only light is small, junk LED flashlight
Tools Needed:
Wire Cutter
Wire Crimper/Needle Nose/etc
2 Quick Connect Female Ends
1 Quick Connect Male End
about 2' of wire
1. Disconnect the horn cable to the horn and you will see a female quick connect end on the cable (male on the horn).
2. Cut your ~2' of wire into 2 1' pieces.
3. Take your male ended quick connect and crimp on the two 1' cables (Make a "Y" cable)
4. (*OPTIONAL*) To clean it up, do a dry "install" and cut off any access cable needed to reach each horn. (Mine has about 8" to passenger side horn and 3" to driver side horn)
5. Crimp on a female end on the end of each cable
6. Connect cable male end to stock cable and tape it up to make sure no moisture gets in.
7. Connect cable female ends to the horns
8. Enjoy your new, fully removable custom dual horn setup!
*PLMK if I need to further explain something!!!!*
Pics:
Stock cable feeding into Y cable taped up
Horn placement (can kind of see the cable)
Cable plugged into horn connector
2009 Magnetic Gray Metallic Corolla LE
^Click For My CarDomain Page^
Team HAMSTER
FlawedLegacy is offline
The Following User Says Thank You to FlawedLegacy For This Useful Post:
cabur (12-15-2011)
post #2 of 23 Old 12-15-2011, 11:59 AM
Dimaoala's Avatar
Quoted: 2 Post(s)
Awesome
You didn't want Hella Horns?
Dim's 2009 Super White Toyota Corolla XRS Turbo!
Dimaoala is offline
post #3 of 23 Old 12-15-2011, 12:02 PM Thread Starter
Lowdown Lowlife
Quoted: 1 Post(s)
(Thread Starter)
after hearing msncorolla's horns I knew I wanted those, plus they were cheaper.
Team HAMSTER
post #4 of 23 Old 12-15-2011, 12:23 PM
Dimaoala's Avatar
Quoted: 2 Post(s)
Ahhh ok, I might as well post the vid here as it's on topic for horns, and it will help people decide between the two
Dimaoala is offline
The Following User Says Thank You to Dimaoala For This Useful Post:
trlhiker (12-15-2011)
post #5 of 23 Old 12-15-2011, 12:50 PM
Senior TN Member
msncorolla422's Avatar
Quoted: 2 Post(s)
You are welcome and glad you like the simple mod much better than stock huh? haha
msncorolla422 is offline
post #6 of 23 Old 12-15-2011, 01:29 PM
trlhiker's Avatar
Quoted: 0 Post(s)
http://www.youtube.com/watch?v=sf9gSVV1ZNg
Those Fiamms sound awesome. Which ones are they?
trlhiker is offline
post #7 of 23 Old 12-15-2011, 01:36 PM Thread Starter
Lowdown Lowlife
Quoted: 1 Post(s)
(Thread Starter)
FIAMM Freeway Blasters. I got mine on Amazon for $18 for the pair
Team HAMSTER
post #8 of 23 Old 12-15-2011, 01:51 PM
trlhiker's Avatar
Quoted: 0 Post(s)
Did you go with the hi or low tones or both? And did you leave the stocks hooked up? And did you need a relay installed? Sorry for all the questions. Definitely want to do this mod.
trlhiker is offline
post #9 of 23 Old 12-15-2011, 02:03 PM Thread Starter
Lowdown Lowlife
Quoted: 1 Post(s)
(Thread Starter)
one of each, removed the stock (one horn is where stock was), plug n play
Team HAMSTER
post #10 of 23 Old 12-15-2011, 02:18 PM
trlhiker's Avatar
Quoted: 0 Post(s)
Thankyou.
trlhiker is offline
post #11 of 23 Old 12-15-2011, 02:22 PM Thread Starter
Lowdown Lowlife
Quoted: 1 Post(s)
(Thread Starter)
of course!!
Team HAMSTER
post #12 of 23 Old 12-15-2011, 05:22 PM
Quoted: 0 Post(s)
so to get the sound similar to the video you need both the high and low tones? These sound much better than stock! The stock horn sound so emasculating...
2011 Magnetic Grey Corolla S - in dire need of lowering springs
ainako is offline
post #13 of 23 Old 12-15-2011, 05:27 PM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 87 Post(s)
Canada
The last horn to me is the equivalent of nails on a chalk board...if you can remember those..
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #14 of 23 Old 12-15-2011, 11:31 PM
cu2cool's Avatar
Quoted: 0 Post(s)
How do the Hella's sound in comparison to the Fiamm's in person? In the video, the Fiamm's sounds way louder. I also did this mod thanks to MSN's inspiration and help. The model numbers are 72112 and 72102. I love their sound together. Like a stock Lexus horn. Bought them for only $10 each, and I had a Groupon, so only spent $10 total. You must run the power to these horns in parallel (as Flawed has done) if you plan on using the stock harness. I tried them in series, but there's not enough power this way. Also Flawed, are you grounding on the radiator? Is that safe? I just ran the wire to a ring terminal I screwed on behind the bolt holding the horn.
LED Bulb Swap, Footwell LEDs, OBX Sport Pedals, 35% Tint, Bungie Trunk Mod, Red Out Tails, FIAMM Hi/Lo Horns, Smoked Eyelids, FX-R BiXenon Projector w/5k HIDs, LED Pipe Eyelids/CCFL Halos
To Do: LED Tails, Vinyl Roof, Oval Muffler Tip, DVD/Nav System, 18" Rims
cu2cool is offline
The Following User Says Thank You to cu2cool For This Useful Post:
msncorolla422 (12-13-2012)
post #15 of 23 Old 12-16-2011, 12:24 AM Thread Starter
Lowdown Lowlife
Quoted: 1 Post(s)
(Thread Starter)
The reason I got them is b/c of them being "Lexus-ish"!
No, the ground it to the back of the horn, there is nothing going to the radiator, just a crap pic most likely.
Team HAMSTER
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix General Discussion Forum
User Tag List
Linear Mode Linear Mode
Back
