There are 2 vents in the trunk on on each side i am in the middle of sound deadening my car right now and the air coming from out side is making my car louder with those vents i am about to take them out then put my sound deadener over the vent spots then call it a day unless someone can tell me why they are there and what purpose they will do if i do cover them up?
2009 Corolla S Enkei Rims
Sundown 1500d
2 Jbl Gti's
Kinetik hc1800.
Big 3 with pics tutorial soon
Unless you drive with your windows open all of the time. The air coming into the interior from the ventilation system needs somewhere to go or it will not function properly. If there is no escape for the air coming in, the system will eventually become less efficient (the interior will pressurize to some degree) and the effectiveness of any ventilation will decrease (increase fogging of the windows and less fresh air).
the only thing though that doesnt make sense about this is that the seats are up and there is no way for the air to get to the trunk any how... So how would the air get to there if everything is blocking it off ex. seats rear dash speakers windows... so how is it going to get to the back of the trunk? However i do drive alot with my windows down and i mean alot. So if i do cover them up what is the worst case scenario?
Sundown 1500d
2 Jbl Gti's
Kinetik hc1800.
just cover all the vents for now. then just find out later what the results are. you can always take out those dynamats anytime you want.
Even with the rear seats up there's still plenty of air moving from the passenger compartment to the trunk area. I would not block those vents, as the air flowing through the trunk will refresh/replace the air in the trunk, inculding damp humid air. Most cars have had some type of flow through vetilation through the trunk for 20+ years. If you like damp humid air to collect in your trunk and start the rusting out process sooner, then go ahead and cover the vents up.
I can think of no good reason to block the vents. All cars have vents.
Jeff
i did block mine for the purpose of less sound in my car and there is less sound now. i also did it in my echo and nothing ever happened. if problems to occur then i will unblock them.
Sundown 1500d
2 Jbl Gti's
Kinetik hc1800.
the vents are located underneath the carpet in the trunk. I will be taking pics of my car when i get done with the whole car doing my sound deadening. so it will be a while befor ei get pics up i still got alot more to do on it and no money right now to do it with.
Sundown 1500d
2 Jbl Gti's
Kinetik hc1800.
The vent hols under the carpet might drain holes if they are in the tire well, if they are higher then the tire wells they may be vent holes to let moist air out as the truck air is colder than the passenger compartment air in the winter.
Why you guys never seen gangster movies? it's to keep your enemies alive till Boss gets to seem em.. I would block but with rubber that's like on vacuum cleaners.. if need be air will go out otherwise stay closed..
