Installing a non-OEM spoiler outside of the dealership will "likely" void your perforation warranty...and anything that is affected by the spoiler. (for example, if the non-OEM spoiler causes some failure on the trunk lid hinge or if rust starts to form near the spoiler, tough luck.
Basically, if you change the intended use or function of that part, and it fails (or can reasonably be attributed to your actions) then you'd be out of luck on warranty.
If in doubt, call Toyota directly.
