2009 Toyota Corolla Bolt Pattern/Offset? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2008, 10:44 PM   #1 (permalink)
View canadian_hustla's Photo Gallery
Question 2009 Toyota Corolla Bolt Pattern/Offset?
Hey Folks,
Anyone know what the 2009 Toyota Corolla wheel offset is?
I am fairly sure bolt pattern is 5x100
Is the offset different for CE/LE/S/XRS?
Thanks and cheers!
-Dave
canadian_hustla is offline   Reply With Quote
Old 09-22-2008, 11:31 AM   #2 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
15-inch Wheels: 15.0x6.0" +33mm Offset, 5x100mm Bolt Pattern
16-inch Wheels: 16.0x6.5" +39mm Offset, 5x100mm Bolt Pattern
17-inch Wheels: 17.0x7.0" +39mm Offset, 5x100mm Bolt Pattern
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is online now   Reply With Quote
Old 09-22-2008, 11:35 AM   #3 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
good info. thanks!
joeylgarcia is offline   Reply With Quote
Old 09-22-2008, 11:57 AM   #4 (permalink)
Thank you so much!
I looked EVERYWHERE for this info and couldn't come up with it
this should be stickied for future reference.
Old 09-22-2008, 01:31 PM   #5 (permalink)
ok so this is a stupid question but if i want to change the rims (16's) to 17's or 18's do i need to change the brakes, springs etc?
thanks in advance
Old 09-22-2008, 03:45 PM   #6 (permalink)
thanks in advance
the answer is no.
Old 09-22-2008, 08:25 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
YOu can leave it stock, but putting nicer rims on a car that's not lowered always looks somewhat funny.
Old 09-27-2008, 12:02 PM   #8 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $105560
View rolla-XRS's Photo Gallery
Canada
Are you sure Jeff? I had picked out a set of 16" winter rims for XRS and had to reneg on buying them because the bolt pattern spacing was not 100mm. It was 115mm (or something like that).
I think the 1.8L engines are running 100mm...but XRS is different.
rolla-XRS is offline   Reply With Quote
Old 09-28-2008, 10:41 AM   #9 (permalink)
Jeff Lange's Avatar
No, the XRS is not different, that information is 100% correct.
Tirerack.com, etc has been listing the wrong bolt pattern since the 10th Gen got released. I think based on the fact that the Matrix has a different bolt pattern for the 1.8L and 2.4L models. 1.8L Matrix models have 5x100mm and 2.4L Matrix models have 5x114.3mm, the Corolla on the other hand does NOT have any models with 5x114.3.
They're all 5x100.
Jeff
Old 09-28-2008, 03:04 PM   #10 (permalink)
View andrewwoo's Photo Gallery
so to clarify:
Corolla 1.8 or 2.4:
CE/LE/S/XRS are all the same 5x100
Matrix 1.8: 5x100
Matrix 2.4: 5x114.3
am i correct?
2009 BLUE Streak Metallic Toyota Corolla S
6000K HID Retrofit TL Projectors| 6000K HID H11 LEDs | Interior White LED Lights | White Cathode Trunk Light
Door Sills | Factory Remote Starter | Ipod Adapter | 15% High Performance Metallic Tint
TRD RSB | UR 19mm RSB | UR LB
andrewwoo is offline   Reply With Quote
Old 09-28-2008, 10:41 PM   #11 (permalink)
rolla-XRS's Avatar
Ahhh yes - you're right Jeff. I had it backwards.
I had picked up a set of Matrix wheels/rubber with (with TPMS) on them for like $300...thinking they would fit my rolla...and had to back out because they didn't fit. So yeah the rollas are all 100mm.
In the end, I should have kept the wheels, pulled the TMPS out and craiglisted the wheels and rubber for $500.
Old 09-29-2008, 09:22 AM   #12 (permalink)
Jeff Lange's Avatar
Originally Posted by andrewwoo View Post
so to clarify:
Corolla 1.8 or 2.4:
Matrix 1.8: 5x100
Matrix 2.4: 5x114.3
am i correct?
Yes.
Old 09-29-2008, 09:31 AM   #13 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
Sweet! So that means I can look around for some xrs alloys to fit on my base trix.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 09-29-2008, 01:10 PM   #14 (permalink)
Jeff Lange's Avatar
Indeed.
Old 01-22-2010, 04:29 PM   #15 (permalink)
View Driver_X's Photo Gallery
So would putting on a 17x7.5 +40mm Offset work, or is to much? I have TRD Springs on a Corolla S with 16's. Wanna make sure that if the back end gets loaded the wheels will still tuck just fine.
Driver_X is offline   Reply With Quote
