Things Id like to do to my 09 Blue Rolla..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2008, 04:25 PM   #1 (permalink)
View jthessin's Photo Gallery
Please respond telling me if its possible!>!>!>!>
I have the dark charcoal interior so I want to paint/Stain all the non black plastic pieces in the passenger compartment.
I also want to do a swap of the guages or lights to make them blue.. anyone know the bulb size for our dash???
Plan on placing under dash lighting in BLUE along with changin out dome light to blue....
Would LOVE to paint the headliaght buckets the matching blue instead of black/same thing for the Sonar Euro Tails as shown here: http://www.autoaccessorystore.com/ho...detail&id=3003
my only real questions is where do i get the paint to do this. google has no real pages for odering this in spraycan or shop form....
Thanks
JIm
jthessin is offline   Reply With Quote
Old 10-28-2008, 06:25 PM   #2 (permalink)
View Just Be's Photo Gallery
Painting your interior plastic pieces CAN be done. However, depending on which pieces you want painted, it can be difficult. For example, if you want to paint the trim around the radio, that can be done fairly easily. However, the dashboard since it is texturized, will require some prep work.
As far as the gauges, that really depends. You have to look at the gauges to determine if you have LEDs or wedge bulbs. If you have wedge bulbs, you can just swap them out (assuming there is no color filter/film on the gauge). If you have LEDs then I would recommend contacting a specialist and swap out your LEDs. Do NOT attempt this if you have no experience soldering, as you may ruin the circuit board.
Lights under the Dash (floor area) can be done fairly easily. Just make sure to use relays before you fry any wires. The Dome light is very very easy...remove trim, remove old light, install new light, re-install trim, sit back and admire your work.
The headlights will be difficult if you have little to no experience and/or patience in dealing with headlights.
If you have doubts, I would recommend taking it to a body shop or an import shop and ask them to do it, so if they screw up, they are financially obligated to get you a new one.
Just Be is offline   Reply With Quote
