Originally Posted by hendrix8989
Well I just bought a new horn, actually it is used..I bought it on ebay. It came off a Acura Legend. Watch out if you buy a horn. The horn on our cars have only one wire (positive). The horn I bought had two connectors (postive and negative). The connectors did not have a positive and negative marked. So you need to figure the connectors out.
most horns have two connectors... positive & ground
the stock horn has the ground built into the brace that attaches it to the frame... at least thats the only place i could figure it could be... I detached the stock horn but left the wire attached and it did not work... then i screwed it back to the frame and it worked... so just make sure any horn you buy, when you install it, you ground it to the frame properly.
