Airbag Off Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2008, 01:51 PM   #1 (permalink)
View facingfear's Photo Gallery
Airbag Off Light
I just recently changed my stock radio to the Kenwood DDX-512 and noticed that the Passenger airbag off light isnt on. I kind of remeber that it use to be on when nobody was in the passenger seat. I wanted to know, anywith the stock radio still installed, is the passenger airbag off light on? Also, anybody with a aftermarket radio, same question.
facingfear is offline   Reply With Quote
Old 11-18-2008, 01:57 PM   #2 (permalink)
CRT > LCD
ZenithTheTV's Avatar
Gameroom cash: $243382
View ZenithTheTV's Photo Gallery
The Airbag OFF light only comes on when there is something/someone in the seat that weighs less than a certain amount but more than 0. If there is nothing/no one in the seat then there should be no light.
Try it with a 20lb weight on and off the seat, you should be able to trigger it.
ZenithTheTV is online now   Reply With Quote
Old 11-18-2008, 01:57 PM   #3 (permalink)
Super White Corolla S
Hoosierbrandon's Avatar
View Hoosierbrandon's Photo Gallery
My passenger air bag light only comes on when there is a person sitting in the seat. Otherwise the light is switched to off.
Hoosierbrandon is offline   Reply With Quote
Old 11-18-2008, 03:48 PM   #4 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
I'm with Zenith.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 11-18-2008, 08:20 PM   #5 (permalink)
TN user
View gizzer777's Photo Gallery
I believe Zenith is correct as well
x2!
gizzer777 is offline   Reply With Quote
Old 11-19-2008, 06:26 AM   #6 (permalink)
Thanks.
Old 11-19-2008, 06:39 AM   #7 (permalink)
Ask your Mother
sinnaever's Avatar
Gameroom cash: $283134
View sinnaever's Photo Gallery
Ya my Lunch Bag has the light come on, and when i take it off the seat, the light goes off... Zenith is right on.
+3
2009 Corolla XRS
2006 Matrix XR
sinnaever is offline   Reply With Quote
Old 11-19-2008, 06:45 AM   #8 (permalink)
AOV
View AOV's Photo Gallery
It only happened once and I had the car a few weeks...my daughter was sitting in the passenger seat, and the Airbag Off light was on. I found that interesting, but as I said, it only happened once. The next time she sat there, it worked as it should.
AOV is offline   Reply With Quote
Old 11-19-2008, 09:20 PM   #9 (permalink)
CRT > LCD
Yup that's cool. If your daughter is light enough, its quite possible that it was just barely underneath the threshold weight, so the OFF light came on. Its designed to do that so smaller children aren't injured by an airbag impact since the seat belt is more than sufficient for them.
It'd also explain that maybe the next time she sat in it, the sensor registered just over the threshold and the ON light was triggered.
In either case, it sounds like its working fine, nothing to be worried about.
Cheers!
Old 11-20-2008, 05:51 AM   #10 (permalink)
View oscarjf's Photo Gallery
that has happened to me too, but i just pull over, turn off the car, turn on the car and the airbag system turns on
oscarjf is offline   Reply With Quote
Old 11-20-2008, 06:13 AM   #11 (permalink)
AOV
Cheers!
She is about 80 pounds.
Old 11-20-2008, 06:16 AM   #12 (permalink)
AOV
So when it says "on"...we are hoping it really works?
Old 11-20-2008, 09:21 AM   #13 (permalink)
jdhog's Avatar
As I understand it the ON or OFF light is only linked to the passenger seat. The drivers air bag is always on. Only when something light in the passenger seat (like a small child) it should say OFF anything heavier will show ON. When you're driving along just you in the car it should not display either OFF or ON.
Old 11-21-2008, 01:21 AM   #14 (permalink)
CRT > LCD
hmmm, not exactly sure how heavy the threshold is set for, 80lbs sounds about right though. But you know what, she might've been fidgiting or shifting around when you noticed it the first time.
If you're really worried about it, you could always mention it when you go in for your next service appointment.
But to me it sounds like everything's alright.
Old 11-21-2008, 05:56 AM   #15 (permalink)
Ask your Mother
sinnaever's Avatar
80lbs is still below the safety regulations for a child in the front seat armed with an air bag. they have it turned off because in the case of a crash the airbag would do more harm than good to her. Not sure exactly what the number is but it is around the 100lbs mark for the Airbag to be on with a passenger in the front.
2009 Corolla XRS
2006 Matrix XR
