Originally Posted by Pandaxpress
1. God damn that must cost alot. How much did you pay for a roll of dynamat and how many sq. ft?
2. What is the expandable foam for? more rattle prevention? Where do you buy it, what is the foam called, and how much does it cost? I know some good spots to use it in.
3. When you do the "Big 3" please make sure to include the type of wire used and the mounting locations.
4. Did you do the bottom of the rear deck from inside the trunk?
Thanks man keep up the good work. Might have more questions for you later.
1. Each bulk pack is 36 sq feet. So far I have bought 4 bulk packs I am using the 4th bulk pack on the headliner I am going to see if 2 layer will fit but not sure wont know till tomorrow. I have been buying my dynamat extreme on amazon or you can buy it on ebay for about the same price maybe save a few bucks but here is my link for the bulk pack.
http://www.amazon.com/Dynamat-10455-...9494228&sr=8-1
It comes to about $135-$140 a bulk pack.
I get mine from dependable resource there the cheapest.
2. I used the expanding foam for the rattles I was hearing some where I couldn't isolate it so I put foam in the c-pillars all the way down to the trunk where the air vent flaps are in the trunk took those out and put dynamat extreme there then fill it with the expanding foam called (GREAT STUFF ) YOU CAN BUY IT AT WALMART FOR ABOUR $4.50 A can as you can see with the pics. Putting in the expanding foam has really made the road noise down I have used 28 cans of expanding foam to get it to be the way I wanted it to be I then has to wait for it to cure took forever like a total of a week since it was so thick on top of each other. But then I shaved down What I didn't need so I will be able to put the carpet back in there. I have not made a mess except for the foam on the seat belt which I will take off soon.
3. I will be using knukonceptz Kolossus fleks cable Not sure though as said if I can fit 4 gauge or 0 gauge where I do it I have not even began to look at locations yet. But I will be sure to post pics when I get to it which will be soon I am enjoying my deadening project to keep the car quiet.
4. Yes I did do the bottom of the rear deck inside the trunk I took the speakers out of the rear deck I am planning on putting 2 (15's) in the place of the 6x9 location and running a Infinite Baffle (IB) setup. Did you need pics of the bottom rear deck?
