Cold... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2009, 12:07 PM   #1 (permalink)
View Berg's Photo Gallery
Canada Cold...
Anyone find it's 2009 a bit slow to start when very cold? (-20 celcius) The engine sometime spins 2 or 3 times before starting. I am not use to this in my Focus wich starts like really quick at that temperature.
I use to put full synthetic in my other cars, this one is still on the regular 5w20 put on last oil change by Toyota.
Just your opinion about the manner of your 09 corolla in the real cold weather (canadian winter) would be appreciated.
Happy new year !
Berg is offline   Reply With Quote
Old 01-01-2009, 01:32 PM   #2 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $105560
View rolla-XRS's Photo Gallery
Pretty common with Toyota's. My other 05 Corolla and 00 Celica were the same way.
I thought I read somewhere that this is part of a warmup safety mechanism for the engine. Don't know the details though...
rolla-XRS is offline   Reply With Quote
Old 01-01-2009, 05:29 PM   #3 (permalink)
imEric!'s Avatar
Gameroom cash: $113357
View imEric!'s Photo Gallery
Canada
My car was using German-Castrol 0w-30 and it never had problems starting in the cold...
Now I'm using Amsoil 0w-20...
.Eric
imEric! is offline   Reply With Quote
Old 01-01-2009, 06:19 PM   #4 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $520719
View LeanBurn's Photo Gallery
Canada
Try plugging in the block heater.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 01-01-2009, 07:01 PM   #5 (permalink)
Thanks guys, I will try putting some Full syntec like in my other cars. Maybe this would help, also I will wait for 5 sec before turning the key once I am at ''On'' position. I also heard like on of you said that Toyota are sometime hard to start in the winter. Well if this is normal, I can easily live with that !!!
Regards,
Old 01-01-2009, 07:05 PM   #6 (permalink)
By the way block heater is also a great idea... I will find and aftermaket one because it is not installed on the car. They asked 178$ + tax in Canada for this option. I have access to a plug at my home and work.
I have enjoyed this on previous car as when you start the car it is already hot. But I heard that Toyota is not heating the coolant but the block, so I don't know if I will enjoy a warm car as before once I start it.
Regards
Old 01-01-2009, 07:37 PM   #7 (permalink)
btk
btk's Avatar
View btk's Photo Gallery
nope.. i haven't had any problems starting my car... and i'm in alberta, and right now its been about -25 to -30 for a month now LOL.. but yeah, my xrs is doin just finee
btk is offline   Reply With Quote
Old 01-01-2009, 10:58 PM   #8 (permalink)
LeanBurn's Avatar
Canada
Block heater = heating coolant in our cars. Its more effective to heat from the inside. Mine only reves to 1200rpm when first started at -25C when I plug it in. I get interior heat pretty quick too.
I am surprised, I thought block heaters were mandatory on all Canadian cars...
Old 01-01-2009, 11:36 PM   #9 (permalink)
rolla-XRS's Avatar
Block heaters are a dealer-installed option. No legal requirement for them since many parts of Canada don't require them. Southern Ontario, Montreal, most of BC are areas that don't need them.
Old 01-02-2009, 12:34 AM   #10 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
They are installed in every Toyota for Alberta though.
Where the block heater is on the newer engines versus it being directly in the coolant on older engines makes little difference. The block is heated and the coolant is inside the block, so it gets heated as well. It may take a bit longer but if you leave your car plugged in for enough time the coolant will get to about the same temperature, I'd think.
Aluminum is the best conductor of thermal energy used to build engines today, about 4-5x more conductive than cast iron.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
